3 Pages123>
max
#1 Posted : Thursday, September 11, 2008 10:33:11 AM(UTC)
max
Hi, I have a GE xl44 model # jgbs23bea5wh gas range. The problem is the oven flame is very low. I replaced the ignitor which didn't solve the problem. I thought I would replace the Valve pn# AP3423440 next. I would like to know if the safety valve could cause this problem or what I can do to trouble shoot this problem. Thank you.
libertyappl
#2 Posted : Thursday, September 11, 2008 12:33:07 PM(UTC)
libertyappl
Do you use natural or LP gas? Did this just recently start?
max
#3 Posted : Thursday, September 11, 2008 1:18:28 PM(UTC)
max
I have LP gas. It's been like this for awhile but I would really like to get it working. The oven won't go above about 275
libertyappl
#4 Posted : Thursday, September 11, 2008 6:13:06 PM(UTC)
libertyappl
Check your oven burner to see if it has any corrosion in it.
Nat
max
#5 Posted : Friday, September 12, 2008 3:12:07 AM(UTC)
max
The oven burner looks clean no visible corrosion. This happened fairly quickly. The first time I noticed a problem I was baking at 350 and the oven wouldn't hold and went down to 275-300 even when I turned it up to broil. It has gotten a bit worse since I first noticed the problem. The burner fires up just fine , the flame is even and blue all the way around.
libertyappl
#6 Posted : Friday, September 12, 2008 5:40:47 AM(UTC)
libertyappl
Check the thermostat. that maybe where yhour problem lies.
Nat
max
#7 Posted : Friday, September 12, 2008 9:49:33 AM(UTC)
max
Electric thermostat Part Number: AP4324689 behind the oven control knob under the front panel ? How would I check it?
libertyappl
#8 Posted : Friday, September 12, 2008 9:58:10 AM(UTC)
libertyappl
The easiest way is with an ohm meter, testing for continuity. If you are uncertain on how to do this there are several posts on testing components.
Nat
max
#9 Posted : Friday, September 12, 2008 10:26:48 AM(UTC)
max
Reads about 1.5 ohms - doesn't change much when I rotate the knob. What should the correct reading be between low and high?
libertyappl
#10 Posted : Friday, September 12, 2008 11:05:26 AM(UTC)
libertyappl
Check for continuity of the part. Not an ohm reading.
Nat
3 Pages123>
