The Rinse ONly light on the front control panel is blinking and the dishwasher will not start. I have recycled the power many times but it did not help. The Cancel button also does not work and when pressed it begins flashing along with the Rinse Only light. How can I test to see if it is the keypad or the control? I have read similar threads but not on this model. Is the testing the same? My model is KUDM0ITJBS0.
THIS FORUM IS DEAD!!!!!!! |
