wimper
#1 Posted : Thursday, September 11, 2008 8:34:17 AM(UTC)
wimper
our maytag washer motor burned up. I ordered a new motor from appliancepartspros but the electronic connectors are the wrong size on wires coming from washer. also the switch on top of motor is color coded and on new motor/switch they are number coded. Also on old motor there are 3 holes for the mount studs to attach to base with the hole to the left of center being used on old motor , new motor only has a center hole and no left or right hole to mount to base.
libertyappl
#2 Posted : Thursday, September 11, 2008 8:46:38 AM(UTC)
libertyappl
The motor for your washer should be AP3720974 (Maytag part 12002351)
There was a parts change on this motor, I'm not sure which motor you ordered.
Nat
