How do I remove the drum on a GE dryer (model DBXR453GV0AA)?
Open the door, look inside at the 12 oclock position remove the screws holding the top down to the front. Raise the top and take the screws off the front from inside and remove the front. The drum will then come out easily. DO NOT take the screws from the back of the inside drum out. Raise up on the drum and carry it out the front.
