I just purchased a used refer/freezer, listed above. The girl said everything worked. I replaced the water filter, and have water through the door. I push the ice paddle, and the rotator turns in the ice tray. There seems to be no water being dispensed into the ice tray to freeze. Any ideas? Thanks in advance, Terry
For starters make sure the arm is down on the icemaker. Nat
I have the same problem not getting water to the ice tray. Ice maker arm is down. I just changed the water inlet valvekit and still is not working. I am getting water to the dispenser in the door.
Robert your best bet is to replace the IM, if you were getting water before hang on to your old valve it's probably good. Nat
