CDouglas
#1 Posted : Saturday, August 28, 2010 3:42:33 AM(UTC)
CDouglas
Our refrigerator is freezing but other side won't keep cool. There is no apparent icing up inside freezer. Any suggestions about what could be causing this.
#2 Posted : Saturday, August 28, 2010 8:18:38 AM(UTC)
Replacement parts for frs20zrgww models | AppliancePartsPros.com
Could not find info on GWW, following tech sheet is for a GW9. Yours should be close
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/218909401.pdf
I would check the freezer temperature first, just to be sure it is low enough. Should be 0 to 5 degrees F.
Looks like there may be a lower vent between the sections (Item 57 in Section 4). Check that it is not blocked on either side.
Check that the evaporator fan runs OK when the compressor is running.
Check that the damper assembly (Item 115 in Section 5) is opening up.
CDouglas
#3 Posted : Saturday, August 28, 2010 11:28:31 AM(UTC)
CDouglas
We are trying suggestions and appreciate your feedack!
