mkell
#1 Posted : Friday, August 27, 2010 5:49:04 PM(UTC)
mkell
The fridge and freezer weren't getting cold enough.I cleaned all coils and vents.I removed the rear panel of the freezer[freezer is under] what I believe were the condeser lines [copper tubing] were frozen over quite a bit of ice behind that panel so I let it defrost for a day then turned back on it worked good for about 2 weeks now the ice is back along with the cooling temps and it seems to be running continuously.I'm not ready to buy a new fridge so any suggestions greatly appreciated.Thanks Mkell
#2 Posted : Saturday, August 28, 2010 2:06:36 AM(UTC)
Replacement parts for BR22S6W models | AppliancePartsPros.com
Here is a manual which I think will be close to your unit
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/4e6dde8efcb9e0f485256ab00056337f/$FILE/4322228.pdf
Sounds like a defrost problem.
First remove the evaporator cover in the freezer so you can see the coils.
Do not let them de-ice.
If they are heavily iced/frosted over you have a defrost problem.
If yes.
Manually force a defrost cycle by turning the defrost timer cam (Item 26 in Section 2) till the fans and compressor turn off.
Now check the defrost heater to see if it is on.
Be careful you do not want to burn your fingers.
If the heater is on then the timer needs replacing, re: it is probably stalling during it's rotation so is never getting into a defrost cycle.
If not on.
Unplug the unit.
Remove the wire for one side of the heating element (Item 7 in Section 4) from the wiring and measure it for continuity, usually around 20 ohms or so.
If the heater is OK
Remove one wire to the defrost thermostat (Item 6 in Section 4) and measure it, should be 0 ohms when frozen. Note that it opens just above freezing so must be frozen to check it. Also inspect it, if it is bulged at all replace it even if it measures OK.
If both the above are OK then odds are the defrost timer contacts are toast.
Best way to test this is a live test to see if you have 120 volts across the heater/defrost thermostat combo.
