phillen
#1 Posted : Friday, August 27, 2010 12:27:42 PM(UTC)
phillen
My GE Side by Side refrigerator Model 363tfx28PBBA is making ice ever so often at bottom and is leaking water to the floor. Is this easy to fix or require a repair professional.
#2 Posted : Friday, August 27, 2010 2:26:12 PM(UTC)
Most likely the problem is a clogged and/or frozen drain in the freezer. The drain hole is under the evaporator and you have to remove the rear panel in the freezer to access it. Defrost it, using a hair dryer, and run hot water through the drain to make sure it is clear. A turkey baster might help.
Here are the breakdown diagrams and Replacement parts for General Electric TFX28PBBAAA Refrigerator | AppliancePartsPros.com
