jmshareef
#1 Posted : Monday, September 8, 2008 9:40:18 PM(UTC)
jmshareef
I have an Amana refrig. side by side doors, when turn the water on the ice maker, there is water under the fridge. The ice maker is working but a lot of water under the fridge. Thank you.
#2 Posted : Tuesday, September 9, 2008 5:06:48 PM(UTC)
Remove the rear cover. Locate the plastic tube (1/4") goes to the ice maker and check it for a small crack. Also check the water inlet valve.
Here are the break down diagrams for the Amana refrigerator Model SCD22TBW
Ice Maker is leaking water under fridge (Refrigerator & Freezer Repair)
by JDay 12/16/2008 10:36:20 AM(UTC)
