josh79
#1 Posted : Monday, September 8, 2008 7:49:14 PM(UTC)
josh79
amana gas dryer starts up and heats for a minute. it makes a noise when i switch from no heat to heat? any ideas???
josh79
#2 Posted : Monday, September 8, 2008 7:52:41 PM(UTC)
josh79
forgot to say i cleaned the vent out.:)
libertyappl
#3 Posted : Monday, September 8, 2008 8:05:36 PM(UTC)
libertyappl
Can you double check the model number it doesn't pull up. That would help a lot
Nat
josh79
#4 Posted : Monday, September 8, 2008 8:22:15 PM(UTC)
josh79
this is what i got for model LG4309W
manuf model# p1163503ww
thank you for the help!
#5 Posted : Tuesday, September 9, 2008 4:49:36 PM(UTC)
If it starts to heat at start up and later it does not relight then, most likely the problem is a bad coils on the gas valve.
- The part number for the coil kit is AP3094251
libertyappl
#6 Posted : Tuesday, September 9, 2008 5:14:16 PM(UTC)
libertyappl
Gene knows these dryers very well.....I'd bet that's your problem!!
Gene,
You have someone requesting you post ..... GE Oven Touch Pad Not Responding
Nat
#7 Posted : Tuesday, September 9, 2008 5:43:32 PM(UTC)
Thanks Nat. Appreciated your help.
libertyappl
#8 Posted : Tuesday, September 9, 2008 5:44:38 PM(UTC)
libertyappl
You're welcome Gene!
Nat
