cptbill911
#1 Posted : Thursday, August 26, 2010 8:33:17 AM(UTC)
cptbill911
Where are the drain lines for the freezer in this unit in the back. I cleaned and defrosted the unit but still have water puddling in the bottom of the freezer from the coils. I was told the drain line may be plugged but the parts manual for the unit does not show the location of it. What am I looking for and where is it located. Do they go into the compressor as I cannot see any drain lines. Where can I find a repair manual for this appliance?
#2 Posted : Friday, August 27, 2010 3:05:33 AM(UTC)
Here are your parts. I used GHB0
Replacement parts for FRS26ZGH models | AppliancePartsPros.com
Take a look at Section 6 Items 62 and 64.
Should be directly underneath the evaporator coils.
It drains into the drip tray under the unit.
cptbill911
#3 Posted : Friday, August 27, 2010 6:24:35 AM(UTC)
cptbill911
Found it! A large black rubber line attached to the corner of the drip tray. It caught me as I didn't expect it to be attached to the corner-it was plugged and cleaned it out. Now I know
Kenmore Elite freezer drain plugged (Refrigerator & Freezer Repair)
by mill1174 2/13/2015 9:13:26 AM(UTC)
