Groups ready for retrieval: Registered
My dryer will not heat. Everything is working otherwise as should be, timer and drum are fine, just no heat??????
Rank: Administration
Groups: Administrators
A model and serial number will be needed to start. I dont even know if its gas or electric. I would start with testing any thermal fuses that may be in the dryer.
