I have a control panel that the button to increse heat for the oven does not work only for lowering.is there a repair.can i get a new control panel? owners book says it covers jdp36,jdp37,jdp39.I can't find those #"s on the unit.I have # dp3680w3ad found under the burner top also part# from front of owners book.164d3333p101.So what model do i have.If i need a control panel what #do i order. Chuck
By looking at your numbers posted I'm guessing your model number is actually JDP36BW3AD Which would make the clokc/control part # AP2633034 Nat
