2 Pages12>
misterfixall
#1 Posted : Monday, September 8, 2008 10:37:52 AM(UTC)
misterfixall
hi, maytag front loader not reaching fullspeed in spin , drains well
libertyappl
#2 Posted : Monday, September 8, 2008 8:24:54 PM(UTC)
libertyappl
I would lean toward the motor controller.
Nat
#3 Posted : Tuesday, September 9, 2008 5:12:21 AM(UTC)
I monitor the current to the motor control board to see if it gets over 3 amp. If no amprobe, check to see if the motor is cutting out or overheating. If so I would check the spin bearings.
misterfixall
#4 Posted : Tuesday, September 9, 2008 9:51:33 AM(UTC)
misterfixall
hi the machine is less than 1 1/2 years old .if i set spin to gentle it spins slower , if set spin to mormal it spins faster, if iset to hi spin it spins much faster. but it does not get to that bat out of hell speed, it is very quiet, so bearing are ok to me. i see only one board in this machine at front console .there does not appear to have wax motor in this model.part # is 34001479, thanks
libertyappl
#5 Posted : Tuesday, September 9, 2008 10:22:16 AM(UTC)
libertyappl
This model doesn't have a wax motor. I'd still check the motor controller.
nat
misterfixall
#6 Posted : Tuesday, September 9, 2008 10:40:18 AM(UTC)
misterfixall
is the motor controler in console at front . i do not see any other board
libertyappl
#7 Posted : Tuesday, September 9, 2008 12:00:07 PM(UTC)
libertyappl
No it's in a "box" attached to the base.
misterfixall
#8 Posted : Tuesday, September 9, 2008 12:31:00 PM(UTC)
misterfixall
this model does not have motor controller model MAH6700aww .i called A.P.wagner . they said there is only one board that does it all ,in console .part #34001479 , if there is a motor controller, what is part number?
misterfixall
#9 Posted : Tuesday, September 9, 2008 12:58:20 PM(UTC)
misterfixall
i think this model is made by samsung , does any one have experience with this model?
libertyappl
#10 Posted : Tuesday, September 9, 2008 1:11:09 PM(UTC)
libertyappl
This model must be one of those not sold in the US. the closest model I have found is MAH6500aww, which has a motor control.
Nat
2 Pages12>
