You have been a member since:: 9/8/2008(UTC) Posts: 1
My Maytag dehumidifier freezes over the outer coils within 10 minutes of start-up. Any suggestions?
please locate the model number so we can look at the breakdown. nat
I would check for a clogged filter, if no filter pull off outer cover and check for a lint clog between the condenser and evaporator. If ok, you have a refrigerant leak, probably not worth fixing.
