decshark
#1 Posted : Monday, September 8, 2008 8:32:23 AM(UTC)
decshark
i have a bosch dishwasher that was in storage for 6 months and now hooked up will not run. when starts it takes in water but thats as far as it goes but it will pump out water after i cancel wash any suggestion would be appriciated :)
#2 Posted : Monday, September 8, 2008 1:36:49 PM(UTC)
Most likely the problem is a stuck wash (circulation) pump. I would recommend to check the manufacturer warranty. I believe the pump should be covered for 2 years.
Here are the break down diagrams for the Bosch dishwasher Model SHU9922 UC/12 (FD 8003-)
decshark
#3 Posted : Tuesday, September 9, 2008 6:10:02 AM(UTC)
decshark
thanks will try that let you know:)
carol kittelson
#4 Posted : Thursday, October 2, 2008 10:16:20 AM(UTC)
carol kittelson
I'm partially in the same boat. Mine has not been used for a yaer and I have to fix the latch problem first. But I did clean out the drain host that goes to the disposal and it did have debre and gunk in it. See my post sept 2008
decshark
#5 Posted : Wednesday, November 5, 2008 7:53:51 AM(UTC)
decshark
hello again have not had time to spare so im only getting back to get my bosch dishwasher running again and need help!took out dishwasher but dont see how to get base off or how do i get to pump ect please help:confused:
#6 Posted : Wednesday, November 5, 2008 2:49:51 PM(UTC)
You have to remove the side panels first, then remove a few screws on the right bottom corner and lift up the tank. Remove the outer door panel to make it easier.
