Originally Posted by: Gene  What is the exact (measured by a refrigerator thermometer) temperature in the freezer?
Gene. Hi Gene, This is Wendy from GE. Your freezer temperature should measure between -5 to +5 degrees F when putting a thermometer in something like ice cream or between frozen packages for a few minutes.
Originally Posted by: reen910  I have a side by side fridge/freezer with water dispenser and icemaker. Ice won;t release into the bin. Water works fine, but no ice. I tried turning freezer down to see if line was frozen, but that dind't work. There is a green light on the icemaker that is solid green, not blinking. Any ideas on next steps to try would be great!
Thanks my ice maker hot point does not get water it will despense water the screw will turn in the tray,the green light shows that the icemaker is on but it willnot get water.any ideals
Make sure the water feeding tube into the ice maker is not frozen.
What is the complete model number of the refrigerator?
