i have a problem with a fridge that is overflowing from the catch tray. The fridge is a relative unknown make - Haier. It doesnt have a freezer section. The drain plug is not blocked and seems to be draining to the tray OK. However the tray is not evaporating.
My kitchen is not humid so evaporation should be taking place. The inside of the fridge is also wetter than i think it should be. I can only surmise something is amiss, but i dont know what?
Check that the condenser fan under the unit is running. If it has one.
Also check that the vents under the unit are clean.
If your drip tray sits over some condenser coils make sure they are clean.
For the interior moisture check that the door seal is clean and sealing properly all the way around the door. On the hinge side sometimes the seal catches on the frame, to solve this give it a light coat of white lithium grease or vaseline.
It could be that the unit is creating so much moisture that the drip tray cannot keep up. You may want to check the interior temperature, perhaps it is too cold and is generating too much condensation. It should be 40 degrees F.
Note: Some units have an energy save switch if your unit has this turn it off. |
THIS FORUM IS DEAD!!!!!!! |
