How do I replace the glass on my Jenn-Air electric cooktop ?
Originally Posted by: bobbroke How do I replace the glass on my Jenn-Air electric cooktop ? Bob, Here are the instructions for changing the cooktop glass on your J/A cooktop. It's not as bad as it sounds, Good Luck, :) :) :) Disassembly Procedures for Models Listed
• JEC8430ADB/W/F/N/S • JEC8536ADB/W/F/N/S • MEC5430BDB/W/S • MEC5536BAB/W/S
Main Top Removal
1. Disconnect power to cooktop. 2. Remove knobs from valve stems.
NOTE: To remove knob(s), slide a rag under the knob and pull upward. 3. Remove cooktop from installation position and place face down on protected surface. 4. Remove screws securing main top to burner box bottom. 5. Remove screws securing control panel box and conduit mounting plate to burner box assembly.
NOTE: Control panel box screws are located in front center and conduit mounting plate screws are located in rear left. 6. Remove main top.
NOTE: Make sure the pieces of insulation, located in the front left and right rear corners, are put back in place. Failure to do so could create excessive cabinet temperatures. 7. Reverse procedure to reassemble, verifying that cooktop frame is properly aligned
