I have a kenmore series 90 washer. I can turn it on and it fills with water but the agitator does not work. What can I do to repair this?
Hi, Kenmore Series 90 is not a model number. Please post the full model number. Does it sound like the motor is running when it should be agitating? Does the washer spin? If this is a direct drive (need model number) and it sounds like the motor is running, but the washer will not agitate or spin I would check the motor coupler. http://ApplianceJunk.com/motorcoupler.pdf
