dcherioke1
#1 Posted : Friday, September 14, 2007 2:11:03 AM(UTC)
dcherioke1
I am replacing the pump motor assembly. How do I take out the pump base? How does the new one seat so it will not leak?
Thanks,
David
Matt / APP Team
#2 Posted : Friday, September 14, 2007 9:50:28 AM(UTC)
Matt / APP Team
Rank: Administration
Groups: Administrators
Once the wires and hoses are removed the pump is only held in by 4 locking tabs. When you unlock them you can lift the pump up and out, replacement is the same just in reverse. Here is the part info and appliance breakdown:
Pump and motor assembly
Parts breakdown
