I took the screws out of the door to remove the front panel so 2 plastic semi wedge shaped parts droped on the floor they are around 2 -3 inches I don't have a diagram for the door. I just replaced the upper control module but I took the bottom part of the panel as well HELP JIM watson
At the top of the door there are screw holes 1 on each side of the latch opening. Those plastic pieces go there to hold the top of the outer panel tight. So seperate the door liner again, now put your screws through the holes at the top next to the opening and start the screw through the plastic piece and on the other side, now put the door liner back together with the outer door. Does this make sense?
