rnti2qt
#1 Posted : Friday, September 5, 2008 12:52:02 PM(UTC)
rnti2qt
I have a Frididaire washer that is about 5-6 years old, and it is not switching cycles. Once I set the timer and pull, the washer begins to fill with water, and once the water level is high, it starts draining and will not catch the next cycle.
#2 Posted : Saturday, September 6, 2008 2:48:12 PM(UTC)
Most likely the problem is a bad timer.
- The part number for the timer is AP2107743
Here are the break down diagrams for the Frigidaire washer Model GLWS1649AS0
Roper Washer will not change cycles (Washer Repair)
by mestes 1/6/2011 7:49:40 AM(UTC)
