:) :) Thanks Gene for the fast reponse about the part. Hpw can I do to replace the part. I will not be able to replace only the spark electrodo bicause I can break it. This piece is attached to a long bar Also I need to replace the valve of the Right front burner I believe the part # is AP3086363 Am I right? It is the one with a red paint. :confused: Thanks.
Why did you duplicate your questions?
