I need parts for a vintage GE electric range but the model number does not come up in parts listings as a valid number, rather leads me to closest match. I believe this to be a sixty's unit. Some of the top switches only work on one setting and some of the burners only heat on one grid, so I need some switches and burners. Unit id is JP303T3WH and the serial number is 0153565 and then there's a space and it looks like the number 10 but a rivet in set right over that. Switches on top are push buttons in a row. I guess I should add a question, what model number should I use for parts searches?
I would recommend to call the customer service (877-477-7278) and ask for Adam. He'll help you.
