drieflin
#1 Posted : Friday, August 20, 2010 11:43:23 AM(UTC)
drieflin
Hello'
I need advice on a stack washer/dryer when in spin cycle , it sounds like an aircraft winding up for take -off. only started six months ago, we don,t use but about 1 time aweek..I'm thinking either transmission is low on grease or maybe the spin bearing is bad or dry, i don't know if its a bushing or sealed bearing, but i do needadvice on how to get to it and check it.
thanks
ApplianceJunk
#2 Posted : Friday, August 20, 2010 11:48:59 AM(UTC)
ApplianceJunk
You maybe correct that it's the bearings that you are hearing, but I always check the simple things first.
It could be something as simple as something caught in the water pump.
If you have not seen it already here is the service manual for your washer.
Frigidaire 27in Laundry Centers Gas and Electric (5995381885) Service Manual
Pulsating loud noise in spin Cycle (Washer Repair)
by gemwise 4/4/2015 9:23:26 AM(UTC)
washer makes bang noise in spin cycle (Washer Repair)
by dls1963 12/9/2012 10:19:09 AM(UTC)
noise in spin cycle only (Washer Repair)
by jakk 7/8/2011 3:01:07 PM(UTC)
Loud metal thumping noise in spin cycle (Washer Repair)
by rockinrobinnm 2/6/2011 8:03:13 PM(UTC)
Washer has loud noise in spin cycle (Washer Repair)
by tonywh 11/3/2010 2:32:55 PM(UTC)
Noise in Spin Cycle (Washer Repair)
by ajv00303 10/27/2010 8:38:01 AM(UTC)
Washing machine noise in spin cycle (Washer Repair)
by jill Campbell 10/27/2010 8:25:29 AM(UTC)
Washer makes heavy noise in spin cycle (Washer Repair)
by Hugh07 6/18/2010 9:36:29 AM(UTC)
by lennym 5/18/2010 3:48:32 PM(UTC)
washer noise in spin cycle (Washer Repair)
by pt_bllrd@yahoo.com 2/18/2010 5:12:30 AM(UTC)
banging noise in spin cycle (Washer Repair)
by wildlilly 1/26/2010 12:58:02 PM(UTC)
grinding noise in spin cycle (Washer Repair)
by makuta13 12/15/2009 9:51:17 AM(UTC)
loud banging noise in spin cycle.. (Washer Repair)
by Bonniekanner 10/17/2009 10:10:35 AM(UTC)
Makes loud bearing noise in spin cycle (Washer Repair)
by dwoutersz 10/12/2009 10:56:12 AM(UTC)
Washer making load thump noise in spin cycle (Washer Repair)
by tngrafix 5/7/2009 4:37:52 AM(UTC)
