Kelvie
#1 Posted : Friday, August 20, 2010 9:05:30 AM(UTC)
Kelvie
The dishwasher control panel seems to be the problem. When pushed to start, the dishwasher does not start. I wait and then try again, still no results.
If I try to disconnect the electrical connection, no better luck. Then maybe the 4th time it will start, but will only go 3 or 4 minutes and then stop again. Finally, it will go through a whole cycle and the dishes will be clean.
What's up? What should I be looking at? Replacing the control board, the dishwasher? Or is something else going on?
Thanks for your help!
