I have a Frigidaire Refrigerator Manufacture date is (10-2007) The refrigerator compartment as well as the freezer is freezing up. I have tried to adjust the thermostat to no avail. If you could tell me the possible cause of this I would be most appreciative. Thanks: BTyson
Set the temperature control in the refrigerator on "1" and the temperature control in the freezer on "coldest". Wait about 24 hours and measure the temperature in both compartments, using a mercury refrigerator thermometer. Post the results. Here are the break down diagrams for the Frigidaire refrigerator Model FRT21TNCW6Gene.
