AppliancePartsPros.com
Appliance Repair Help
Washer Repair
inner tub spin CCW (about 2 inches) during agitate
During agitate cycle, the inner tub spin counter clock wise about a couple of inches. Is this normal for this model? I can hold the tub and it would stay. I took the brake assembly apart and the brake looks good. I ordered a new brake and stanor just incase.
The tub also appears to vibrate a bit during spin cycle... Does this means i need a new snubber?
bump for your information...
I replaced the break recently and this fixed the problem. It keeps the tub from spinning during agitating cycle. I'm not sure why but the vibration also went away. I did not have to replace the snubber.
I hope this helps someone.
Washer Repair
