mazdaboss
#1 Posted : 15 years ago
mazdaboss
Washer will not completely drain and will not spin any ideas on easy fix?
Model # whdsr316g2ww
sidfink43
#2 Posted : 15 years ago
sidfink43
I am wondering if maybe you have two problems.
The pump on this model is electric, so it either works or it does not. If all of the water is not draining you may have a partial blockage in the pump or drain hoses inside the machine. Check it out by taking off the front panel. You can do this by inserting a putty knife or screw driver in the gap between the top and front near the edges and releasing the clips that hold the front panel on.
If you have a blockage, clear it and try the machine. If it is still not working right, use this site to trouble shoot the error codes, which are displayed as a flashing light on the inverter on the motor. Before you do any repair, reset the machine by following the directions on that site. Many times this will fix things.
HydroWave GE Washer Repair Guide
GE washer will not spin (Washer Repair)
by MS104 9 years ago
GE washer will not spin with heavy load (Washer Repair)
by carpe 11 years ago
by Rico Whiskey Delta 11 years ago
GE washer will not spin or agitate (Washer Repair)
by tarzandude43 12 years ago
Ge washer will not spin or agitate (Washer Repair)
by Paul Di 14 years ago
GE Washer will not spin on heavy loads (Washer Repair)
by hmorton 15 years ago
GE Washer will not spin (Washer Repair)
by tcpr12 15 years ago
by bfreeman91080 15 years ago
GE Washer will not spin or agitate (Washer Repair)
by casshley 15 years ago
by tcahapw 16 years ago
GE washer will not spin nor agitate (Washer Repair)
by Evans 16 years ago
ge washer will not spin or agitate (Dishwasher Repair)
by m-fuson 16 years ago
GE Washer will not spin on rinse cycle (Washer Repair)
by mguy77 17 years ago
by csol147462 17 years ago
