glenn ross
#1 Posted : Saturday, August 30, 2008 9:08:35 AM(UTC)
glenn ross
How to you remove oven top to get to the screws holding clock cover plate on?
ApplianceJunk
#2 Posted : Saturday, August 30, 2008 10:53:14 AM(UTC)
ApplianceJunk
You do not have to remove the top.
You need to remove the control panel.
glenn ross
#3 Posted : Saturday, August 30, 2008 11:56:37 AM(UTC)
glenn ross
There are 6 screws holding the front plate to the oven body. 4 can be accessed by opening the door. I can see 2 others holding the plate to the oven body that are located between the top of the plate and the oven top. Top has to be removed to get to them to remove the plate.
Glenn
