Rank:: Member
Machine runs but does not continue to next cycle, light says heating delay. Turned off high temp rinse, and high temp wash, left heated dry on. Machine still did not continue to second cycle but after manually moving dial, completed other cycles and dry. Hot water to machine is 125 d. Dishes are always clean and dry, just have to move dial to get to next cycle.
Unplug motor and remove inner door panel and turn power on. Probe the contact of the timer that sends voltage to the timer motor. If no voltage, spray the timer with a non-residue spray while turning the timer. This should fix the problem. Sometimes some timer pins may work loose, just push in on them and that should fix the problem.
