I have just bought a seconhad creda upright freezer and took it home in a van on it's side(did not know it was not reccomended) switched it on right away and obviously it is not working, i have since left it switched off and idle for 24 hrs tried again but just the red light and no freezing??
Is it goosed or will it start in time??
cheers.
Originally Posted by: dafty  I have just bought a seconhad creda upright freezer and took it home in a van on it's side(did not know it was not reccomended) switched it on right away and obviously it is not working, i have since left it switched off and idle for 24 hrs tried again but just the red light and no freezing??
cheers. It's probably a "goner". If you laid it on it's side, you may have allowed the oil and refrigerant to pass into the condenser coils, and you now have a clog in that component, and it wont cool. I would not expect it to cure itself, but you never know. When you power it up do you hear the compressor start/run ? Good Luck, :cool: :cool: :cool:
Cheers for the reply.
No sound at all only the light comes on and nowt else.
Originally Posted by: dafty  Cheers for the reply.
No sound at all only the light comes on and nowt else. I wonder if you knocked something off underneath or in the compressor area,Loose wires or something else ? You should be able to hear the compressor, start and run, when you turn on the control.
It was laid on it's side in the back of a transit then placed in position, i have hoovered all round the compressor area etc but it is still dead.
There is no evidence of a loose wire etc, there is however some dust type stuff falling out from inside what looks like a copper pipe with lagging on it which runs the full height of the freezer??????
cheers again
Originally Posted by: dafty  It was laid on it's side in the back of a transit then placed in position, i have hoovered all round the compressor area etc but it is still dead.
cheers again I've been trying to research this for you, and don't seem to be getting help. I cannot find a CEEDA freezer on the internet, I can find a CREDA web sight. I'm just wonderring, where are you located ? It seems, this unit is manufactured in europe. It may require a 210 Volt 50 hrz circuit, if you're here in the USA , You may need a "drop down" transformer to make it operate. You may have to surf the internet for Better information than what little bit I have. :) :) :)
Am in Scotland, i never paid a lot for it so may just look for another one;)
thanks for your efforts anyway:)
Originally Posted by: dafty  Am in Scotland, i never paid a lot for it so may just look for another one;)
thanks for your efforts anyway:) Just wish, I could have done more for you. Good Luck, :cool: :cool: :cool:
