grego4u
#1 Posted : Monday, August 16, 2010 12:18:24 PM(UTC)
grego4u
The shaft seal where the drive shaft goes thought the bottom of the tub leaks when the washer is running. I was wondering how big of a job this is. I am very handy and have done lots of washer repairs over the years but I have never taken one this far. Looking for a little advise before I buy the part.:eek:
Thanks,
GregO:cool:
Joe / APP Team
#2 Posted : Monday, August 16, 2010 1:48:49 PM(UTC)
Joe / APP Team
Thanks,
GregO:cool:
Sure,
You can do it, You'll need a special tool, and hammer, but it is pretty clear cut.
you've most likely have a leaking tub seal, tub bearing assembly.
Here's a sight that will break everything down for you,(even part numbers).
It will really be an asset for you, to have.
Good Luck,
Maytag Tub Seal Replacement
#3 Posted : Monday, August 16, 2010 3:42:37 PM(UTC)
I have done a few of these. Only comments are, I used a steel punch to punch up and out the old sleeve bearing, there are half round slots in the tranny shaft to facilitate this. Also, I use non-detergent, 10 weight oil on the sleeve bearing before installing. This is about a two hour job.
Guest (4)
can I do this myself (Washer Repair)
by ca6tz 7/1/2008 7:52:03 AM(UTC)
CAN i DO THIS (Oven Repair (including Ranges and Cooktops))
by dawgtired 3/24/2008 3:18:40 PM(UTC)
Can I Do This Repair Myself?? (Dishwasher Repair)
by pmaxp 8/18/2007 6:01:47 AM(UTC)
