lil2spunki
#1 Posted : Friday, August 29, 2008 5:28:32 AM(UTC)
lil2spunki
This will probably be very simple and I have done some research so hopefully this will confirm what I have learned. My dryer runs but the heat never kicks on. I don't hear it attempt to ignite the heat. I have cleaned out any lint and debris (which was not alot) from the vents.
I would like to get my parts ordered today and I am not quite sure which part to start with. Should I just go ahead an order a thermal fuse and see if that does the trick or should I also order the thermostat in conjunction with the fuse?
Thanks for any advice.
