Clothes Mover Stopped Working I Took Off The Agitator But Can't Get The Clothes Mover Off I Am Going To Order The Repair Kit But How Do I Know If The Cam Is Long Or Short
You will need part number AP3094543. which goes under the fabric softener and cap, remove the bolt and then the parts go there.
Clothes Mover Stopped Working Took Agitator Off But Can't Get Apart To Order Reair Kit
Please click one of the Quick Reply icons in the posts above to activate Quick Reply.
Did you remover the whole thing or just the top part?
I Know That But How Do I Get The Mover Off To Get To The Cam
I Took The Whole Unit Out
if you go to the FIND PARTS page select Whirlpool and put your model number in the space you can see how it goes together(in the case comes apart)
Is There A Trick To Pull It Apart
remove the fabric softener on top then under that remove the cap
