bmrnc
#1 Posted : Saturday, August 14, 2010 10:15:48 AM(UTC)
bmrnc
Have deforst problem on side by side frigid / freezer. Checked deforst thermosat and is ok, heater measures correct resistance. Not able trigger deforst cycle mannually when triggering light switch 5 times in 6 seconds. Where is the deforst cycle timer located? With digital controls? Is there any adjustments or if it will not trigger does it mean it is cooked? Any other tests?
#2 Posted : Saturday, August 14, 2010 2:08:43 PM(UTC)
Replacement parts for FRIGIDAIRE GLHS68EEB0 Frigidaire/refrigerator | AppliancePartsPros.com
Here is a wiring diagram
http://manuals.frigidaire.com/prodinfo_pdf/Anderson/240389620.pdf
And a manual
http://frigidaireservicetips.com/pdfs/496_4.pdf
Looks like your unit uses Genesis controls. This control info starts on page 30.
Forcing a defrost uses the diagnostics.
