lilydog
#1 Posted : 15 years ago
lilydog
Wine cooler started freezing at the back wall. It formed a sheet of ice and gradually lost cooling ability. Replaced the thermostat and still no luck. The interior light and cooling fan both work ok. I did notice the rear vinyl wall was bowed out like it was inflated with air. It is normal now, but the unit won't cool at all. I'm guessing it's either the relay start, compressor. What should I try next??
#2 Posted : 15 years ago
If the compressor is running, but no frost on the evaporator, you have system problems for a pro to look at.
