Vincent20
#1 Posted : Wednesday, August 27, 2008 6:50:29 AM(UTC)
Vincent20
Freezer is fine but refrig is not cold at all.
Please help.
libertyappl
#2 Posted : Wednesday, August 27, 2008 9:35:13 AM(UTC)
libertyappl
Check the back of the freezer for frost/ice(may need to remove the rear panel in freezer to check completely. If so locate the defrost timer and advance until the unit shuts down. let us know how that goes.
kayakcrzy
#3 Posted : Thursday, August 28, 2008 5:35:53 AM(UTC)
kayakcrzy
This product does not have a defrost timer, it has a adaptive defrost control, which is a board. If you have a frost build up, on the back wall of the freezer, that will most likely be your problem. The part # is 61005988. If you need to be walked through the repair, let me know. Tom ApplianceEducator.com
