This gas dryer will start but the heat does not continue, it shuts down after several minutes. Vents have been cleaned and dryer does not dry the clothes. I currently have the front panel opened and do not see any notable defective parts e.g. thermostat/sensor? Any thoughts or suggestions would be appreciated. Thanks
Check all the thermal fuses for continuity. If one is bad that will keep it from heating up, also test your ignitor. Post your results
