Recvd an F1 error on a 3 yr old Amana slide in range, plan to replace Control board (part# AP3464263). Do I also need to replace 2 thermistors (part #s AP3757728)?
This is for a Whirlpool F1 code, but that code means the same on virtually all brands. Try this: You have either a bad ERC (clock) or a bad touch pad. Here is the procedure for determining your problem. [LIST=1]
Disconnect power to stove Gain access to the back of the clock (electronic range control or ERC). Unplug the touch pad ribbon connector from the ERC. This will be a flat wire apx. 1 1/2" to 2" wide. Make sure everything is clear and will not short out when power is turned back on. Turn power back on to stove. Watch for codes and listen for the beep. If you get a code and beep, replace the ERC. If after apx. 30 minutes you do NOT get the F1 and hear the beep, replace the touch pad. NOTE: Some models incorporate the touch pad and the clock as one part.[/LIST]
I followed the advice on the F1 error as written. After disconnecting the membrane switch pad, the beep stopped and F1 error went away. I replaced the membrane instead of the ERC and saved $100. Everything working fine!:)
Glad you saved some $$! And got it going too. Nat
