My Samsung Refer started leaking from the inside on to the floor about two weeks ago.It happens about once a day.It is a side by side.The water comes from the refer side.Any help or suggestions would be greatly appreciated.Tim
Originally Posted by: Tim Cruse  My Samsung Refer started leaking from the inside on to the floor about two weeks ago.It happens about once a day.It is a side by side.The water comes from the refer side.Any help or suggestions would be greatly appreciated.Tim Tim, Remove the lower bins in the refrigerator, Remove the lower cover of the air tunnel in the center of the compartment, and check for a leak in the tubing or tank, for the water supply to the dispenser assembly. Based on your information, thats where you will find the problem. :) :) :)
