BAG
#1 Posted : Tuesday, August 26, 2008 4:46:14 PM(UTC)
BAG
I was replacing the springs in my oven door. While putting the door back together, I broke a small tab off the bottom of the side trim. While checking online for a replacement, I found out that this piece was no longer available. Instead, I was referred to a new trim kit the manufacturer had made available. Now, I have the door trim replacement kit, but can't get the glass front to fit with the side trim pieces in place.
Has anyone else had the same problem?
HELP!!!
#2 Posted : Wednesday, August 27, 2008 1:15:11 PM(UTC)
What is the part number for the trim you used?
