The machine won't spin or agitate, and makes a loud clisking noise when it is trying to spin. I have taken it halfway apart, and it is a direct drive system, but have yet to remove the motor to inspect the coupler or the gearcase. Any timesaving suggestions?
The easiest way it to raise the top remove the front panel, remove the clips on the pump and move out of the way pull the coupler, replace and reinstall the pump
