buck032
#1 Posted : Tuesday, August 26, 2008 10:58:04 AM(UTC)
buck032
I Awoke To The Front Of The Dryer Had Clothes Stuck In It And The Dryer Had Run All Night. All The Clothes Were Grey Spotted And After Removing The Clothes The Whole Front Of The Drum Dropped And The Felt And Long Thin Metal Pieces Were In The Clothes And Drum. Is It Even Worth Fixing ?
libertyappl
#2 Posted : Tuesday, August 26, 2008 11:15:42 AM(UTC)
libertyappl
You should be able to just replace the seals on the drum, check the rear seal and rollers too. But it's probably worth fixing. unless it cut a lot of metal off the front of the drum or panel.
Nat
