tmoceri
#1 Posted : Thursday, August 12, 2010 9:55:32 AM(UTC)
tmoceri
My ice maker has stopped making ice. Are there some steps to take that will lead me to the problem?
Joe / APP Team
#2 Posted : Thursday, August 12, 2010 10:48:49 AM(UTC)
Joe / APP Team
There are 2 systems involved, for your icemaker to make ice
The ice maker and fill valves and tubes
And the infra red sensor system in side the liner of the freezer.
Check and make sure the water tube to the ice maker is not frozen,
and check the solenoid resistance for 500 to 1000 ohms.
De ice the fill tube or replace the valve as needed.
To test the sensor system : make sure the switch on the right control panel is on.
Close the freezer door for 1 minute then open, the red light should be on solid/steady.
If the light pulses or no light at all, close the freezer door and wait 1 minute.
Open the freezer door, and press the flapper panel on the left side of the wall, if the light pulses or no light at all replace the emitter/reciever kit.
Part number: AP3137510
If tube and valve check ok, if sensor system checks ok, replace ice maker assembly.
Part number: AP3182733
tmoceri
#3 Posted : Thursday, August 12, 2010 11:47:17 AM(UTC)
tmoceri
Joe,
I removed the ice maker assembly to remove excess ice thinking the build up may cause the unit from working. Prior to doing so the sensor light was blinking after opening the freezer door. Now, after re-instralling the assembly, the light is just off after I open the door. If the wire harness came loose when I took the assembly out would it prevent the sensor from working?
tmoceri
tmoceri
#4 Posted : Thursday, August 12, 2010 11:50:00 AM(UTC)
tmoceri
Joe,
Go figure. I just checked again and the sensor light now is back to blinking after opening the freezor door.
tmoceri
Joe / APP Team
#5 Posted : Thursday, August 12, 2010 1:57:55 PM(UTC)
Joe / APP Team
Joe,
tmoceri
You will need to replace the infra red sensor system.
The light should be on "solid" when you open the door.
Also check for a sticky door switch.
Ice Maker Not Making Ice At All Times (Refrigerator & Freezer Repair)
by danrclem 6/11/2023 6:52:52 PM(UTC)
Whirlpool WRF535SMBM00 Ice maker not making ice (Refrigerator & Freezer Repair)
by Derek Halter 3/7/2023 12:03:25 PM(UTC)
LG Refrigerator LFX21960ST Ice maker not making ice (Refrigerator & Freezer Repair)
by tfmc369 9/19/2022 9:02:45 AM(UTC)
Under Counter Ice Maker not making ice (Refrigerator & Freezer Repair)
by ling_appliance 3/13/2022 5:55:41 AM(UTC)
FRS26KF6EM4 Ice Maker not making ice (Refrigerator & Freezer Repair)
by johnhurst 9/3/2021 10:14:18 AM(UTC)
Maytag ice maker not making ice, I don’t know what else to try... (Refrigerator & Freezer Repair)
by Karnsky 12/11/2020 5:09:39 PM(UTC)
Whirlpool Ice Maker Not Making Ice (Refrigerator & Freezer Repair)
by hanginghelmet 5/8/2016 2:24:52 PM(UTC)
Whirlpool Ice Maker not making ice (Refrigerator & Freezer Repair)
by turbotribes 8/1/2015 9:44:31 AM(UTC)
by kidmims 7/25/2015 9:41:54 AM(UTC)
Ice Maker not making Ice. (Refrigerator & Freezer Repair)
by atticus1 6/11/2015 5:28:24 PM(UTC)
by gaff 11/13/2013 7:29:05 PM(UTC)
Ice maker Not making ice (Refrigerator & Freezer Repair)
by chavisfamily1234 11/2/2012 8:52:20 PM(UTC)
by cgoodwin 8/2/2012 11:07:55 AM(UTC)
by Guido 6/22/2012 9:40:34 AM(UTC)
Kenmore Ice Maker not making Ice (Refrigerator & Freezer Repair)
by ghauptman 5/25/2012 1:47:12 PM(UTC)
