Every now and than washer will flood the laundry room with water this first happened about 1 year ago and just recently the other day. Not sure if I should expect the timmer or water switch
I cannot find any info on the given model number, please check it.
I would suspect that the water level switch is the culprit.
Another possibility would be that there is something between the tubs that blocks the air pressure tube for the water level switch every once in a while. |
THIS FORUM IS DEAD!!!!!!! |
Sorry I had given you the serial # Here is the model # LSQ8543JT0. Also where would the air pressure tube be located? Thanks for your help.
