MY WASHING MACHINE WILL RUN THROUGH THE WASH CYCLE. BUT WILL NOT RINSE AND RUN THROUGH THE SPIN CYCLE. PLEASE HELP? THANKS, DESPERATE FootballMOM75:(
Check to see what water temp is coming in on the wash cycle, test on cold only. If you don't get water in then it's probably you water valve. Part number AP3094541 Hope that helps, post your findings Nat ( also a football Mom)
