mimiki
#1 Posted : Monday, August 25, 2008 4:40:18 PM(UTC)
mimiki
my food was getting frozen on the bottom compartment, i replaced the defrost timer and the temperature control but didnt work the last time i workwed on it i cleaned the condenser but still doing same thing ,freezing the food on the bottom compartment,please help me:confused:
libertyappl
#2 Posted : Monday, August 25, 2008 5:30:46 PM(UTC)
libertyappl
Drop the control panel and check the damper arm make sure the damper is closing properly, if needed the part number is AP2990695
Also chekc and make sure the thermostat tube barrier is in place.
hope that helps
Nat
Help :-( I dont know what to do (Refrigerator & Freezer Repair)
by AngelJ77 3/30/2012 8:07:55 AM(UTC)
