YODAUSA
#1 Posted : Wednesday, August 11, 2010 10:38:06 AM(UTC)
YODAUSA
nEED HELP HERE PLEASE. Left washer idle for three months, upon our return. It would not put enough water in to get started. I opened the door and watched, I see water bubble but not enough pressure to raise the center wand. We put a large container of water inside (as to prime ) and it seemed to get it going. I closed the door and I could hear the center wand turning a spraying water. What could be the problem, it seems to go through all the cycles after we first prime it. Any help would be appreciate, thank you
Joe / APP Team
#2 Posted : Wednesday, August 11, 2010 12:04:29 PM(UTC)
Joe / APP Team
Views messages in topic : 5,222
You most likely have debris in the water line and fill valve screen.
Making for a slow, weak fill of water.
I would flush the water supply line to the fill valve and replace the valve,
if it were me.
(see attached/click number for part information)
Part number: AP2039343
